Hi all.
Im teaching myself revit at the moment on my macbook pro, running through parallels and the computer is struggling. Has anyone experienced this ? Any ideas on how to get around it ? I've listed the specs below, I'm looking foreward to using the new programme but my macheine is making it very difficult!
Any help with this would be great!
I would recommend bootcamp as you get full dedicated support from the Hardware.
Also for parallels, check how much memory you are allocating for the windows session. I would recommend 4GB min
try this page out it has recommendations on setting the parallels settings for revit.
http://www.bimtopia.com/index.php/item/tips-for-improving-revit-performance-on-a-mac
Use Full-Screen or Window. Avoid Coherence to preserve performance.
If you have a Dual Core, select 1 processor. If you have a Quad Core, Select 2 processors.
Give as much memory as you can spare to Parallels. On the 4 GB MacBook Air, I give Parallels 2 GB (the minimum needed for Revit to runwell). On the 8 GB MacBook Pro, I set this to 4 GB.
Performance: Faster virtual machine
Disable “Enable Adaptive Hypervisor”
Enable “Tune Windows for speed”
Power: Better performance
Free Space: Disable “Automatically compress virtual disks”
Integration: Disable “Isolate Mac from Windows” if you want to store your Revit project files in a Mac folder.
Share Folders: All disks
IMPORTANT >>> Shared Profile: Disable “Share Mac user folders with Windows” (if left enabled, this will really slow down Revit file operations to a crawl)
SmartMount: Enable “Map Mac volumes to Windows”
ShareWindows: Disable “Access Windows folders from Mac”
Disable “Share Windows applications with Mac”
Disable “Share Mac applications with Windows”
Disable “Use Crystal Mode”
Enable “Disable Windows Aero”
Disable all options
Enable all options
SmartMouse: Auto
Copy & Paste: Enable “Share Mac clipboard”
Video Memory: 256 MB
Turn on “Enable 3D acceleration” -- while disabling 3D acceleration may improve performance slightly, many analysis and simulation programs require it. If you do turn off 3D acceleration and find that programs are no longer display graphics reliably, turn it back on to see if this setting change fixes the problem.
Control Panel > System > Advanced System Settings > System Protection tab > Configure… > Turn off system protection.
Right-click C: drive > Properties > General Tab > Disable “Allow files on this drive to have contents indexed...” > Apply changes to drive C:\, subfolders and files.
Disable” Compress this drive to save disk space”
If you can avoid installing anti-virus software by practicing safe-computing, do so. Anti-virus software can cause significant system slowdowns.
Disable “Use Hardware Acceleration” -- note: this setting can be tricky. Some newer video card emulations are not understood by Revit's hardware acceleration, so it's often better to disable it. But, to graphically display the results of some types of analysis -- for example, the wind tunnel simulation in Vasari -- it must be turned on. The best setting to use is likely to change as the software gets updated in new releases.
Disable “Use Anti-Aliasing for 3D views”
