Running Revit architecture on a macbook pro 2011
1 REPLY 1
jenny.keating
2328 Views, 1 Reply
Hi all.
Im teaching myself revit at the moment on my macbook pro, running through parallels and the computer is struggling. Has anyone experienced this ? Any ideas on how to get around it ? I've listed the specs below, I'm looking foreward to using the new programme but my macheine is making it very difficult!
  • Processor type: Core i5 (I5-2415M)
  • Processor speed: 2.3GHz
  • Turbo boost: 2.9GHz
  • RAM type: PC3-10600 DDR3
  • 8GB RAM
  • Video Card: HD Graphics 3000
  •  Parallels running Windows 7 (should I be using Bootcamp instead ?)
Any help with this would be great!
1 REPLY 1
BIMologist_
in reply to: jenny.keating
I would recommend bootcamp as you get full dedicated support from the Hardware.
Also for parallels, check how much memory you are allocating for the windows session. I would recommend 4GB min
try this page out it has recommendations on setting the parallels settings for revit.
http://www.bimtopia.com/index.php/item/tips-for-improving-revit-performance-on-a-mac
Configuring Parallels Desktop for Macintosh – Version 7
  • View Mode
Use Full-Screen or Window. Avoid Coherence to preserve performance.
  • Virtual Machine: Configuration: General: Number of CPUs
If you have a Dual Core, select 1 processor.  If you have a Quad Core, Select 2 processors.
  • Virtual Machine: Configuration: General: Memory
Give as much memory as you can spare to Parallels. On the 4 GB MacBook Air, I give Parallels 2 GB (the minimum needed for Revit to runwell). On the 8 GB MacBook Pro, I set this to 4 GB.
  • Virtual Machine: Configuration: Options: Optimization
Performance: Faster virtual machine
Disable “Enable Adaptive Hypervisor”
Enable “Tune Windows for speed”
Power: Better performance
Free Space: Disable “Automatically compress virtual disks”
  • Virtual Machine: Configuration: Options: Security
Integration: Disable “Isolate Mac from Windows” if you want to store your Revit project files in a Mac folder.
  • Virtual Machine: Configuration: Options: Sharing
Share Folders: All disks
IMPORTANT >>> Shared Profile: Disable “Share Mac user folders with Windows” (if left enabled, this will really slow down Revit file operations to a crawl)
SmartMount: Enable “Map Mac volumes to Windows”
ShareWindows: Disable “Access Windows folders from Mac”
  • Virtual Machine: Configuration: Options: Applications
Disable “Share Windows applications with Mac”
Disable “Share Mac applications with Windows”
  • Virtual Machine: Configuration: Options: Coherence
Disable “Use Crystal Mode”
Enable “Disable Windows Aero”
  • Virtual Machine: Configuration: Options: Full Screen
Disable all options
  • Virtual Machine: Configuration: Options: Modality
Enable all options
  • Virtual Machine: Configuration: Options: Advanced
SmartMouse: Auto
Copy & Paste: Enable “Share Mac clipboard”
  • Virtual Machine: Configuration: Hardware: Video
Video Memory: 256 MB
Turn on “Enable 3D acceleration” -- while disabling 3D acceleration may improve performance slightly, many analysis and simulation programs require it.  If you do turn off 3D acceleration and find that programs are no longer display graphics reliably, turn it back on to see if this setting change fixes the problem.
Windows 7 Settings
  • Turn off System Restore
Control Panel > System > Advanced System Settings > System Protection tab > Configure… > Turn off system protection.
  • Turn off File Indexing
Right-click C: drive > Properties > General Tab > Disable “Allow files on this drive to have contents indexed...” > Apply changes to drive C:\, subfolders and files.
Disable” Compress this drive to save disk space”
  • Anti-Virus Software
If you can avoid installing anti-virus software by practicing safe-computing, do so.  Anti-virus software can cause significant system slowdowns.
Revit Options Settings
  • Graphics
Disable “Use Hardware Acceleration” -- note: this setting can be tricky.  Some newer video card emulations are not understood by Revit's hardware acceleration, so it's often better to disable it.  But, to graphically display the results of some types of analysis -- for example, the wind tunnel simulation in Vasari -- it must be turned on.  The best setting to use is likely to change as the software gets updated in new releases.
Disable “Use Anti-Aliasing for 3D views”
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
