RSACCELERATOR2014 vs " Manage Connection to Revit Server Accelerator"
2 REPLIES 2
b_ralphs
362 Views, 2 Replies
Is there any differenct between the RSACCELERATOR2014 Env. Var. & Collaborate Tab -> Synchronize panel drop-down -> Manage Connection to Revit Server Accelerator?
It doens't look like one updates the other. I would think if they did the samething they would....
Tags (1)
2 REPLIES 2
Lance.Coffey
in reply to: b_ralphs
When I change the RSACCELERATOR2014 user variable (in the Environmental Variables dialog) on my system, I am seeing that the Accelerator listed in Revit (in the "Manage Connection to a Revit Server Accelerator" dialog) is changed (after closing and re-opening Revit).
Which of these are you changing, and then finding the other is not modified?
Lance Coffey
Technical Support Specialist
b_ralphs
in reply to: Lance.Coffey
Oh I was setting a System Environmental Variable, I now see it's a User Environmental Variable, daaaa.
