Rounding up length parameters
3 REPLIES 3
14735 Views, 3 Replies
Hi
I am making a Schedules for metal flashings that i have added to my project. I have not had any problems using shared parameters to get the length of my line based families and everything is working fine.
But now comes the tricky part. I need to somehow add a parameter that would roundup my real lengths to my production lengths. f.eks i have couple flashings that are 2569mm And what i would like the schedule to show is that I have couple of 3000mm flashings.
Is anyone getting me?
I have been reading about formular but havent really found the answer so i was hoping somone here could help?
Regards
Sigurjón
3 REPLIES 3
CoreyDaun
You have to do a little bit of unit manipulation with a formula, but you can force the rounding to a specific increment. Below is an example.
Parameter Name        Value          Formula
TrueLength          |  2569 mm  |  =
RoundedLength  |  3000 mm  |  =  roundup(TrueLength / 500 mm) * 500 mm
The above parameter, "RoundedLength", will return the value of "TrueLength" rounded up to the nearest 500 mm.
Welcome to the Autodesk forums, sigurjon81!
Feel free to post any questions you may have! There are many experienced users here who generously contribute their time and effort to supporting
their peers. This is an open, peer-supported forum, so feel free to contribute any useful information or experiences to any of the topics you see here.
We hope you'll stick around a while and help strengthen the value of this community!
Be sure to review the Ground Rules, visit the FAQ Forum, and use the Search feature prior to posting a question, as it's likely been asked before.
Tags (1)
in reply to: CoreyDaun
Quick question.
I am using 2011 version, which doesn't have the "roundup" function. Is there any way to do that in 2011?
CoreyDaun
peterlyh wrote:
"Quick question.
I am using 2011 version, which doesn't have the "roundup" function. Is there any way to do that in 2011?"
I believe that you can. I don't currently have 2011 to test with, but this should work. You will need to add a third parameter as an Integer to force the number to round. This will also add a little extra formula work to force it to specifically round up.
IntegerLength     |  5              |  =  TrueLength / 500 mm
RoundedLength  |  3000 mm  |  =  IntegerLength * 500 mm + if(IntegerLength * 500 mm < TrueLength , 500 mm, 0 mm)
