In using the Stair Tag that comes with Revit out of the box, it has a label reporting the riser data that we need to have rounded. The label is the "Actual Riser Height". We need to keep the Project Units set at 1/256 but round the label down to an 1/8. Any thoughts on how to accomplish this? Look at the Stair Tag.rfa file.
You should be able to accomplish this using the following:
Edit the stair tag family > highlight the label > Edit Label > highlight the label parameter > Edit Parameters Units Format > un-check Use project Settings > specify Rounding to desired format:
Video Example: http://screencast.com/t/ZTQ4NWEy
Thanks a million for the answer. I've got a conduit fitting tag you just fixed for me.
