I would like my window (and door) families to include a rough width that will cut a masonry opening in a wall. To do that, I created a test family and put a formula on the Rough Width line that says Width + 4”. The Type Properties window shows the opening correctly, but there is nothing showing in my “project” where the rough opening would/should be, and that I can dimension to. Is there a video or other type of tutorial that shows what the proper procedure should be to do this?
Phil
Solved by Alaaeldin_Alsahli. Go to Solution.
When you say the word (showing), Do you mean
Showing the parameter in the properties palette
or
showing the rough opening in the model to snap dimension it
I mean "showing the rough opening in the model to snap dimension it".
Thanks, Phil
Then assign the reference plane as strong ones to be able to snap dimensioning it
The list below is considered as strong References
