Rotating a plan elevation symbol.
5 REPLIES 5
401 Views, 5 Replies
Hi
I got a few newbie problems.
My grid is only appearing on one level.
I believe this maybe because the grids in elevation don't cross over the
levels.
However these elevation grids don't appear because, I think, the plan
elevation symbols are perpendicular to my rotated grid.
How do I rotate them so they're perpendicular?
Cheers
Dave F.
5 REPLIES 5
I'm a little confused with your question, however to rotate anything, just
click on it and hit the rotate command. It's on the top row of buttons,
next to move & copy.
"Dave F." wrote in message
news:5339714@discussion.autodesk.com...
Hi
levels.
Cheers
Dave F.
> the plan
That should have read: aren't
I don't think you can rotate the symbols using rotate.
I've been told the way to do it is to draw a wall which the symbol does
snap to.
Cheers
Dave F.
> Hi
> levels.
> Cheers
> Dave F.
You've been told? Don't be scared to try stuff, it's amazing what you'll
find out by experimenting. Well, I can tell you that it works fine.
There's actually 2 ways to rotate a elevation symbol.
1. Click on it and select the rotate command.
2. Click on it and use the rotate icon that shows up next to the symbol.
news:5340530@discussion.autodesk.com...
> the plan
snap to.
Cheers
Dave F.
> Hi
> levels.
> Cheers
> Dave F.
if you draw a wall you ensure that your elevation is pointing exactly where
you want it to point (i.e. parallel with the elevation).
using the rotate command is fine if you know what the rotation should be,
but if you don't and decimal places are involved you could be a little bit
off - which will be a problem when someone measures off the exported dwg
elevation (which they will, even if you tell them not to)
"C Ryan" wrote in message
news:5340644@discussion.autodesk.com...
> the plan
snap to.
Cheers
Dave F.
> Hi
> My grid is only a
> levels.
> Cheers
> Dave F.
you can also move that little rotation icon that shows up to a reference
point and rotate it.
"sonya" wrote in message
news:5340662@discussion.autodesk.com...
> the plan
snap to.
Cheers
Dave F.
> Hi
> My grid is only a
> levels.
> Cheers
> Dave F.
