if you draw a wall you ensure that your elevation is pointing exactly where
you want it to point (i.e. parallel with the elevation).
using the rotate command is fine if you know what the rotation should be,
but if you don't and decimal places are involved you could be a little bit
off - which will be a problem when someone measures off the exported dwg
elevation (which they will, even if you tell them not to)
"C Ryan" wrote in message
news:5340644@discussion.autodesk.com...
You've been told? Don't be scared to try stuff, it's amazing what you'll
find out by experimenting. Well, I can tell you that it works fine.
There's actually 2 ways to rotate a elevation symbol.
1. Click on it and select the rotate command.
2. Click on it and use the rotate icon that shows up next to the symbol.
"Dave F." wrote in message
news:5340530@discussion.autodesk.com...
> the plan
> elevation symbols are perpendicular
That should have read: aren't
I don't think you can rotate the symbols using rotate.
I've been told the way to do it is to draw a wall which the symbol does
snap to.
Cheers
Dave F.
C Ryan wrote:
> I'm a little confused with your question, however to rotate anything, just
> click on it and hit the rotate command. It's on the top row of buttons,
> next to move & copy.
> news:5339714@discussion.autodesk.com...
> Hi
> I got a few newbie problems.
> My grid is only a
ppearing on one level.
> I believe this maybe because the grids in elevation don't cross over the
> levels.
> However these elevation grids don't appear because, I think, the plan
> elevation symbols are perpendicular to my rotated grid.
> How do I rotate them so they're perpendicular?
> Cheers
> Dave F.
