I have seen several posts about rotating a view on a sheet and the text not remaining readable.
I have seen the posts that say to rotate the view then add text... What if you didn't plan that far ahead - are you just stuck?
Is there any new developments on this?
I have a client who needs to be able to this without having to rotate all the text in the project.
Thanks!
LD
Okay - I have attached an image from my client - The problem they are having is the text on the left -
the view is placed on a sheet and rotated... When they put text in it is rotating as you can see on this image that it is rotating in an odd way.
They are wondering if this is a bug...
Any thoughts?
Lisa
Below is their response...
It does not change anything in the parameters location; although, I did some blog research and found that it might be within the family itself. I can't find where that family is located. Do you know? Its not in the typical family location.
I am not sure what family they are referring too - do you?
Lisa
Hey Lisa,
Are you meaning that the user wants to rotate the viewport but the text to remain horizontal (ie not rotate)? If so, this is still a request item logged with development and has not changed in 2014.
Oh for cryin' out loud. I don't even care if this is related anymore...
If I rotate a text box, it's masking box and outline become offset from eachother. What gives?
Why am I dealing with yet another Revit Annotation headache? Why is this our job? Why do you get to lay it on the users to create add-ons and fixes and finds. Why can't you test your own junky software before releasing it. Sony does it. Xbox does it. Atari did it. What century are we living in?
This is our last subscription. Revit has proven and remained a totally incomplete and incompetent program with way too much energy required to maintain it. This stuff should be out of the box Autodesk. Need I remind you the cost of these suites. Small firms can't afford 100's of packages just to create a set of drawings becuase all you included was an un-orthoed dumpy looking pos chair. Oh yeah, I forgot. Autodesk doesn't write software. They buy it, button it up and then sell it to a third party who in turn sells it to us.
Not that anyone at Autodesk could possibly know but as a side note, WHY HAS THIS ISSUE BEEN LOGGED WITH DEVELOPMENT SINCE 2014? What the F are they doing over there? Seriously. How many developers does it take? That's not a programming joke. How big is the company? Is this one of the best companies to work for because no one actually has to do anything? None of the bugs are EVER fixed in new releases. I feel like being a lot meaner but that's not what this is about. I don't like finding we got ripped off every day that we use Revit. It feels as unprofessional as I would like to be right now.
Not expecting an ounce of resolution on this so take it as you may.
I usually would ignore such posts...but this one is an exception.
With regard to the problem you are having with rotating text box...
PS: There is no such thing as incompetent software very simply because software do not perform on their own...there can be incompetent humans who doesnt know how to use a software (regardless if that software is perfect or not)
Cheers,
RD
And I attached a screenshot for you showing that it does not work at all. Thank you for proving my point on all fronts though man. Much appriciated.
I can't speak for others but I can speak for myself; I don't get paid for trying to help others but I do love doing it whenever I have the time to. However; I am selective...I prefer to help those who are worthy of being helped. The least, those who have a minimum level of respect and maintain a professional level of comunication. Read your post and think again which of the above criteria does it meet
As for a snapshot attached...I just hope there is a fortune teller on this forum who can tell what was behind your snapshot maybe then that FT can solve your issue. As far as I am concerned you may stick to Atari and Playstation and XBox as you deem those more reliable products
If a text object can be written in terms of a direction of the inclination angle it has been defined within the parameters of his family. But we do not see this parameter.
We have to wait for future updates on the developer of the program to show the angle of inclination parameter of the text object.
