From the help file (note line 2)
*Concrete Paver,
;%TYPE=MODEL
0, 0, 0, 5.656, 5.656, 3.3125, -8
0, 0, 3.3125, 5.656, 5.656, 3.3125, -8
90, 0, 0, 5.656, 5.656, 3.3125, -8
90, 3.3125, 0, 5.656, 5.656, 3.3125, -8
45, 3.3125, 3.3125, 8, 8, 3.3125, -4.6875
-45, 3.3125, 0, 8, 8, 3.3125, -4.6875
Blake Middleton wrote:
> Yes, it is a drafting pattern, but when I try to import it as a model
> pattern, it says none exist in the .pat file. How do I create a model
> pattern?
> Blake
> "Aaron Rumple"
wrote in message
> news:5147286@discussion.autodesk.com...
> Did you make it a model or a drafting pattern?
> Model patterns can be rotated. Drafting patterns cannot as they are relative
> to the view.
> To rotate a model pattern, tab to select any edge in the pattern and then
> just use the rotate tool.
> "Blake Middleton" wrote in message
> news:5147281@discussion.autodesk.com...
> I have custom patterns that I have imported into Revit from a pat file, but
> how do I change the angle of the pattern in a filled region to be what I
> need it to be? Surely you don't have to redo the whole pat file (pain in
> the butt) just to rotate the pattern? Thanks.
> Blake
