Revit Architecture
Revit Architecture
Active Member
Craig Cernek
Message 1 of 4 (564 Views)
Rotate Beam about it's Axis?
564 Views, 3 Replies
02-29-2004 07:41 AM
I would like to use the double angle beam to represent the steel lintel over a garage door in a double wyithe masonry wall system.
The problem is that the Revit supplied double angle beam has the back-to-back vertical legs of the angles pointing downward and not upward as is common.
My attempts to rotate the beam on its axis 180°, to direct the back-to-back vertical legs upward, are ignored by the program.
I am unable to find any other controls and program which would allow me to represent the steel being appropriately.
Has anyone found a way to represent this?
Active Contributor
andrewg07
Message 2 of 4 (564 Views)
Re: Rotate Beam about it's Axis?
03-01-2004 06:47 AM in reply to: Craig Cernek
What I did was to take the LL Double Angle family, & invert the beams in the family.
I posted the new family & catalog file in the Revit customer files section, if you'd like to try it.
Active Member
Craig Cernek
Message 3 of 4 (564 Views)
03-01-2004 07:56 AM in reply to: Craig Cernek
If you are referring to the Autodesk Revit customer Gallery, a search for your username found zero results.
*Greg Cashen
Message 4 of 4 (564 Views)
03-01-2004 09:35 AM in reply to: Craig Cernek
It's in the revit.community.customer-files newsgroup "Craig Cernek" wrote in message news:5744845.1078156688566.JavaMail.javamailuser@localhost... > If you are referring to the Autodesk Revit customer Gallery, a search for your username found zero results.
