I would like to use the double angle beam to represent the steel lintel over a garage door in a double wyithe masonry wall system.
The problem is that the Revit supplied double angle beam has the back-to-back vertical legs of the angles pointing downward and not upward as is common.
My attempts to rotate the beam on its axis 180°, to direct the back-to-back vertical legs upward, are ignored by the program.
I am unable to find any other controls and program which would allow me to represent the steel being appropriately.
Has anyone found a way to represent this?
