RoomBook Export Excel Error
1 REPLY 1
sjanczura
444 Views, 1 Reply
I have a issue when trying to export to Excel the results of calculation
I am using Revit 2015 64-bit and Excel 32-bit ( I don't know if its the versions probelm or not ?)
I get the following error:
"The export operation failed because Microsoft Excel cannot be opened. Ensure that the Excel application
is correctly installed".
Is anyone having simillar error ? How to solve it ?
1 REPLY 1
info
in reply to: sjanczura
I´m sorry, because I can´t help you, but perhapes together with my similar question, we will get an answer soon.
My Problem is, that I´m running Revit in a VM on my Mac and so  I´m using MS office for mac. While using the Roombook Extension it was said to export to excel, but when I try, I get the same message as you, Revit wasn´t able to find/open excel. It seems, the extension dosn´t produce a file, it want´s to open MS excel and run the process later on. That wouldn´t be a probleme, but How can I tell Revit where my excel is?
How can I link Revit Roombook to my currently installed excel, using MS office for mac?
Would it work, if I install openoffice on Windows?
LG Jan
Rail Community
