I have a project in wich rooms functionality is compromised. I don't know why the room tool doesn't recognise a simple room delimited by walls whose property divides rooms is set to yes. If I place a rectangle of rooms delimiters the room tool works properly instead. If I start a new project the tool works properly. Thank you.
I would expand the box made of Room Separating lines beyond the walls to find where the break is. I would also try changing the Room Computation height to see if the Room shows up.
