Revit Architecture
Valued Contributor
kwihae
Message 1 of 2 (550 Views)
Room tags
550 Views, 1 Replies
12-22-2011 06:15 AM
How do you make a room tag that references the following?
Structural floor level
Finish floor level
Finish ceiling level
Structural celing level
Room objects are not "aware" of the information you are wanting to tag.  The only way to get this information to display in a room tag would be to create a shared parameter that is arrached to the rooms in the project and then create a tag to read the shared parameter.
The one problem with this would be the fact the information reported in the tag will not be filled out automatically.  it will have to be coordinated and updated manually.
Employee
loboarch
Message 2 of 2 (539 Views)
Re: Room tags
12-22-2011 08:29 AM in reply to: kwihae
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
