How do you handle placing Room Tags on Views other than the main Floor Plan
view?
I've got several types of Views (Ceiling plan, Finish plan, Furniture plan,
Equipment Plan, Demo Plan, etc, etc). If I create each of those Views by
doing a Duplicate with Detailing, I understand that the Rom Tags are copied
to the other Views and are then View dependant.
My question is, how do I keep the Room Tags up to date? I know that if a
room tag's data is changed, it will be updated in all views, but what
happens when Tags are added or deleted? Since the Tags are View
specific,they don't get changed on the Ceiling plan. If I have 5 different
Views of the same Level, does this mean I have to manually make sure all
five views get changed? That just seems very un-Revit to me.
I don't really want to dilute the question, but I also have a large floor
plate, which has to be split into 4 Zones to fit on the plotted sheet.
Since I have 5 types of plans, with 4 Zones each, now may I have to manually
update 20 separate Views whenever I add a new Room Tag! the question is not
about the zones, it's about the duplicate Tags. The Zones just make it
worse.
