Hello Dellboy,
> Hi all
> can anybody help me with scheduling room tags.
> the problem i have is that when i insert a room tag into a project and
> then
> create a schedule from these room tags it will only allow me to
> schedule t
> he room areas in either square feet or square metres depending on the
> proje
> ct standards.
> i work in the housing market and i really need to be able to schedule
> both types of areas from the one tag.
> at present i am having to create a separate parameter and enter the
> square feet in manually, which is rubbish because it doesn't update
> automatically
> thanks in advance
You can add a calculated parameter to the table, for it's value enter the
AREA*(your conversion factor here) then it'll update automatically.
