Room tagging
3 REPLIES 3
dmarshall
201 Views, 3 Replies
Room tagging
Hi all
can anybody help me with scheduling room tags.
the problem i have is that when i insert a room tag into a project and then create a schedule from these room tags it will only allow me to schedule the room areas in either square feet or square metres depending on the project standards.
i work in the housing market and i really need to be able to schedule both types of areas from the one tag.
at present i am having to create a separate parameter and enter the square feet in manually, which is rubbish because it doesn't update automatically
thanks in advance
3 REPLIES 3
in reply to: dmarshall
Hello Dellboy,
> Hi all
> then
> schedule t
> proje
> ct standards.
> automatically
> thanks in advance
You can add a calculated parameter to the table, for it's value enter the
AREA*(your conversion factor here) then it'll update automatically.
Technically you are not scheduling room tags. You are scheduling rooms and
including area as one of the columns. Schedules provide full flexibility in
formatting area columns. Go to formatting tab of schedule properties, select
Area and press Field Format... button. Format dialog comes up. Uncheck "Use
project settings" checkmark and specify what you want.
wrote in message news:5244580@discussion.autodesk.com...
Hi all
standards.
thanks in advance
If you need to have two columns one in sq.meters and another in sq.feet
create a calculated value column = area and apply different formatting.
"Leonid Raiz" wrote in message
news:5244767@discussion.autodesk.com...
Hi all
standards.
thanks in advance
