Room tag
2 REPLIES 2
z.galic
308 Views, 2 Replies
Room tag
Hi all!
Does anybody knows how I can get the finished floor material from the floor in the room tag? The only way I know is to manually write material via Change Parameter Values in the tag.
Regards, Zvezdana.
2 REPLIES 2
LisaDrago
in reply to: z.galic
Hello and Welcome to the Discussion!
So in the Room Tag - the Floor Finish Parameter or any of the finish parameters for that matter are are not going to 'read' the actual materials in the floor, walls etc.. It is an instance parameter that you would fill in for each individual room. If you want the actual materials you would need to have a separate material tag that would read the materials.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
z.galic
in reply to: LisaDrago
Thank you Lisa, but how I can get a material tag? I can't find the template...
ZG
