The box around the room number on the Room Tag is too big. I opened the family to edit but there were no lines indicating the box size. Is there any way to adjust?
Edit the family, go into VG, Annotation Categories and check the show annotation categories in this view box. Once you check this you will be able to see the box around the text and then you an adjust the box to your preference.
LD
