I am trying to make room tags on the second level of this project however if you look at the attached it is not piking up the interior partition walls as room boundaries even though the box is checked that they are room bounding. I do have open doors in some areas however when i changed them to a default door the same issue occurred. My cut plane is at 7' (pic is attached), And I've tried limit offsets of 7' - 12-8" my walls are only 12' in height. I don't know what else to do to get these tags correct. The annoying thing is that they are correct all on the first floor, its only the second floor that is giving me a hard time. PLEASE HELP this has been bugging me for 2 days now.
You can also try to verify :
Constantin Stroescu
