Room/Spaces from Link Model not showing
3 REPLIES 3
3821 Views, 3 Replies
We are using Revit 2014 and I am linking the Architectural Model into the MEP model.  However, the rooms/spaces in the architectural is not showing up in the MEP model, there's no room listed in the room schedule.  I know i can always recreate the space/room but i am trying to avoid that step.  In Revit 2013 i was able to tagged rooms and other items from the Architectural model.  Please help
3 REPLIES 3
maciejwypych
To make sure that the rooms are actually there, check if the phase of the schedule is set correctly (do the same for views), and also, if the rooms are in a linked model, check the include elements in links.
Also, check if the worksets in the Architecural model are all on and set the VG for the link to custom and turn everything on.
in reply to: maciejwypych
Thanks for the reply maciejwypych,
The problem was the phases of the link'd Architectural model and the MEP model didn't match up.  Once i matched the phases everything showed up.
-brian
maciejwypych
Happy to help
