We are using Revit 2014 and I am linking the Architectural Model into the MEP model. However, the rooms/spaces in the architectural is not showing up in the MEP model, there's no room listed in the room schedule. I know i can always recreate the space/room but i am trying to avoid that step. In Revit 2013 i was able to tagged rooms and other items from the Architectural model. Please help
Solved by maciejwypych. Go to Solution.
Thanks for the reply maciejwypych,
The problem was the phases of the link'd Architectural model and the MEP model didn't match up. Once i matched the phases everything showed up.
-brian
