I have a floor plan that has 3 different levels that I want to show, so I'm using a Plan Region to show the levels below cut at the correct hieghts. I'm using the Lower Level as the floor plan, and I want to show the Garage and Entry levels on the same plan.
Garage 7950'-0"; Entry 7951'-0"; Lower Level 7956'-0".
The issue I'm having is where to put the Rooms/Room Names? If I put them all on the Lower Level, then I have to do a (-) offset for the rooms to go down to the floor level for them to show in the Plan Region. If I place them on the respective levels, i.e. "Garage" on the Garage Level, they do not show in the Plan Region I created on the Lower Level Plan.
Are Room Names view specific, in that they only appear in the vewi they are created in? I can select the Room in any view or the Plan Region, but the Room Name is only visible in the view I created it in.
What am I missing/What's the best practice for this scenario? Thanks much. mpp
Solved by AJA14. Go to Solution.
