I've a problem drawing this roof...
I've tested a lot (maybe more) of sketch but it still doesn't work.. 😞
If someone could help me!?
Thank a lot!!
sabatierae
I don't think it is possible to get exactly what you are after. The geometry of where the breaks in the roof are will simply not allow the slopes to point exactly in the direction you are showing. I was able to get close by creating a flat roof and then adding split lines where the slope breaks. i then used shape editing tools to adjust the points and edges for the roof to get the slopes you are after. I was able to match the slopes you showed, but the 11 percent portion will simply not slope directly to the right as you have shown, this is NOT possible from a geometry standpoint. Attached is an image about as close as i can get it.
Thank for your answer.
It's the methodology I was looking for . And split lines are perfects!
thx!
