chrisparrish
469 Views, 3 Replies
Roof
I need to figure out how to change my roof from a hip roof, to a gable roof. If anyone could help, I would appreciate it. Thanks.
3 REPLIES 3
in reply to: chrisparrish
Select the roof and click the button which says "Edit Sketch" in the options bar above the editting window. On the hipped edges, there is an angle symbol. Select the edges you want to be gabled instead and uncheck the check box which says "Defines Slope" (again, in the options bar above the editing window). Click the button labelled "Finish Roof" in the Design Bar. Voila! Greg "chrisparrish" wrote in message news:26783230.1071854110834.JavaMail.jive@jiveforum2.autodesk.com... > I need to figure out how to change my roof from a hip roof, to a gable roof. If anyone could help, I would appreciate it. Thanks.
Select the line and uncheck "defines slope" The line would be the one where the hip starts. Dig? "chrisparrish" wrote in message news:26783230.1071854110834.JavaMail.jive@jiveforum2.autodesk.com... > I need to figure out how to change my roof from a hip roof, to a gable roof. If anyone could help, I would appreciate it. Thanks.
facinox
Pls can anyone give me tips on how to create a concrete roof fasia
