I am working with the Revit 2015 Roof Truss Framing Extension for the first time and was successful in getting the trusses to lay in on a simple rectangular building. To do that, the extension asks for you to pick a roof, which I did. The trusses are then placed with their top surface at the top surface of the roof, thereby resulting in the trusses conflicting with the roof materials (sketch below). How do you set up the roof so that the trusses react to the bottom of the roof?
Thanks, Phil
Thank you for your post. In this case one other means of support on this extension could be the direct support link listed in the applications download. For this one (I believe the name is now Timber Framing), is listed as Support Contact: rex.support@autodesk.com. Please feel free to email this alias direct to engage further with the development team of this extension and application. They may have some additional information as well on best practices and overall use. For reference I have include the link below to this extension and its details. Thank you.
Timber Framing Extension: https://apps.exchange.autodesk.com/RVT/en/Detail/HelpDoc?id=appstore.exchange.autodesk.com%3Atimberf...
