I have this house Im trying to make on Revive and I can't get the roof to join together at all. I've had this problem for awhile now and I can't seem to get past it. I've done everything I can think of to try and fix it but I can't seem to get it. anyone have some suggestions on what it might be?
Solved by constantin.stroescu. Go to Solution.
can you draw a rough handsketch of what you want to obtain? It is not clear for me what you want to do....
Constantin Stroescu
i want to join the second floor roof with the first floor porch roof. it keeps saying that it misses thetarget face.
try these:
Constantin Stroescu
I've made a screen recording of what I have described in my previous post...maybe it helps....
https://chronicle.autodesk.com/main/details/20991dc4-56e7-471f-9c02-dfc06724533e
Constantin Stroescu
I've tired what you told me to do and Im still getting the missed target face error.
I was trying to make the roof again with the vidoe you send me of you doing it and everything goes good until i have to set to cutoff level. Whne i go to set off the cutoff level to level 3 the top of my roof is about a foot over from where it should be cuttoff. I think i can make the roof work with this tutorial you sent me if I could get the cutoff to work.
The bottem of the roof is the part that is getting cutoff when i need the top of my roof to snap to the bottem of level 3.
do you refer to this alignement?
If this is it , then you can use a Cuttof Offset.
Constantin Stroescu
