Do the tutorials on roofs. As for the clay tile, if you have a hatch pattern you typically used in acad, copy it and put it somewhere in your library, Read the revit.pat file, it will tell you how to change and acad pattern file into a revit model pattern. then you can create a new pattern in revit using this.
