Hi Jeffrey,
I had problems when using the linework tool on screened objects (overlay's),
even if I used the "wide" line.. For some reason it just came out "wide
screened".
I'll try it again. :o)
Paul Monsef
TSA | architects, pllc
Production/CAD Manager
425.401.6828 x105
paulmonsef_NOSPAM_@tsaarchitects.com
"Jeffrey McGrew" wrote in message
news:419b91e9$1_1@newsprd01...
> Paul Monsef wrote:
>> To show the Roof DARK I simply turn on the roof above as an underlay and
>> trace over the edges with WIDE detail lines, locking the lines to the
>> roof so they update...
> You should also look into the 'linework' tool. If you use it to make lines
> bold, those lines will continue to show even when the underlay is then
> turned off. So it's a more automatic way to do what you're doing now. I
> use it to make, for example, a dashed line on the floorplan for overhead
> elements like a skylight.
> Jeffrey
