I am new to Revit having previously used AutoCAD Architecture.
What I am trying to do is to model a roof using Revit Lt so that the roof tiling and battens carry on over the gable wall.
Is it possible to add a void profile to the roof slab in order to achieve this or do I need to model a small section of roof to just cover the wall portion?
Solved by constantin.stroescu. Go to Solution.
Solved by b-k-bourgaize. Go to Solution.
I'm not quit sure I understand you well...Is it this what you want ?
If it is so , you can do it as follows:
Constantin Stroescu
If you want to Cut everything I would recommend using a Void:
Component > Model in Place > Generic Models > Name it > make an Extrusion as you want to be the cutter - declare it Void ( from Properties > Identity Data) . Select the Void and from Geometry > Cut - select one by one the Void and first roof, the void and second roof the void and the wall. It will cut all the entities ( because the void was created as Generic Model)
Constantin Stroescu
