Why do roof opening cuts become unselctable after I've edited them a few times? I know it's there. I can see it cutting the roof. I can still select two others. But now I can't select this one and there's no logical reason why!
AutoCAD 2010
AutoCAD 2015
Revit 2015
Solved by kwg06516. Go to Solution.
The solution to any problem in Revit according to a colleague of mine is to fist copy the problem object, delete it and paste it back into the same place, which worked for this instance. Some bug was locking me out of editing the cut and it got stopped by the copy/paste.
AutoCAD 2010
AutoCAD 2015
Revit 2015
