Roof Clipped Eaves - No overhang
1 REPLY 1
2198 Views, 1 Reply
Please see enclosed images.
I am looking to be able to draw a clipped eaves as per attached PDF, also with corbelled eaves shown drawn
quickly on sketchup.
Also is it simple to insert timber trusses as part of the roof structure?
Any help would be aprreciated.
1 REPLY 1
LisaDrago
Hello - I am thinking the fascia command will get you what you want. You can create the profile to be what you want and use that in the fascia command.
As for inserting the timber trusses WITH the Roof - No you cannot do this. The roof command is totally separate from putting in any bracing. The Roof is based off of layers of material and any bracing would be a family.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
