Ribbon missing Edit Profile....? REVIT 2013 PLEASE HELP
2 REPLIES 2
1324 Views, 2 Replies
This is very annoying, i must click the ribbon view three times whenever i edit a profile. For example, i have a wall that i need to edit the profile of, the edit profile tool doesn't show up on the ribbon so i need to click the black arrow, then it shows up when it should have been there in the first place. Then to use the edit tool i need to click the black arrow again. I used revit 2013 on other devices and they all have the complete tool set.
I need to know a fix that works.
2 REPLIES 2
Alfredo_Medina
For Revit 2013, the fix that works, for sure, is to install the service packs, 1, 2, 3, in order.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
edwin.prakoso
If installing the service packs don't work, it was related to graphic cards. I've seen similar issue even the SP already installed. Are the other computers using the same graphic card as yours? If they do, do they have the same driver version as yours?
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
