Revit Architecture
Revit Architecture
Member
p.day
Message 1 of 10 (709 Views)
Ribbon Behavoir Revit LT 2013 following Revit LT 2014 install
709 Views, 9 Replies
05-15-2013 05:47 AM
Hi
I have just installed Revit LT 2014 and now the contextural tab when editing or creating a floor for example no longer appears. (No red X, green tick or lines)  This appears to be a similar issue that happened with Revit architecture 2012 when .Net4.5 is loaded.
Does any one know of a fix. I need to be able to continue running 2103.
Employee
davissc
Message 2 of 10 (692 Views)
Re: Ribbon Behavoir Revit LT 2013 following Revit LT 2014 install
05-15-2013 09:16 AM in reply to: p.day
yes, make sure you are running the latest version of Revit 2013 SP2. There is also a hotfix available by searching on Autodesk.com
Scott D Davis
AEC Technical Specialist
North American Sales
Want Revit Content? Go to http://seek.autodesk.com !
masurawo
Message 3 of 10 (641 Views)
05-21-2013 06:44 PM in reply to: davissc
I cannot find a hotfix of Revit LT 2013.
Please teach me Direct URL.
Member
p.day
Message 4 of 10 (631 Views)
05-22-2013 01:24 AM in reply to: masurawo
HI
Likewise I couldn't find any hotfix mentioned in earlier post.
Due to time restrictions I ended up having to remove LT 2014 and revert
to 2013 only. I will have to investigate further at a later time.
regards
Paul Day
on Behalf of Marson Rathbone Taylor
The information contained in this communication is STRICTLY CONFIDENTIAL and may be legally privileged. If you have received it in error, any disclosure or copying of all or any part of the contents is prohibited.
T 01789 292383
F 01789 292012
E Office@mrtarchitects.co.uk
I www.mrtarchitects.co.uk
Employee
Joe.Charpentier
Message 5 of 10 (621 Views)
Re: Ribbon Behavior Revit LT 2013 following Revit LT 2014 install
05-22-2013 07:54 AM in reply to: masurawo
More details on this issue (including download links) here:
http://revitclinic.typepad.com/my_weblog/2012/05/revit-2013-2012-contextual-panels-do-not-display-or...
The root cause is installing .NET4.5 (which Revit 2014 uses) but you might see this in other situations.
Note there is no hotfix for r2013, only for r2012.  For r2013, to get the UR, you simply have to launch the updater from communication center (the satellite dish in the upper-right corner)
There is a hotfix for r2012:
http://revitclinic.typepad.com/my_weblog/2013/03/revit-2012-hotfix-available-for-net-45-contextual-t...
Joe
New Member
eddierocketship
Message 6 of 10 (580 Views)
06-05-2013 10:08 AM in reply to: davissc
where?
DarrenP
Message 7 of 10 (574 Views)
06-05-2013 10:54 AM in reply to: eddierocketship
where what?
New Member
eddierocketship
Message 8 of 10 (566 Views)
06-05-2013 12:39 PM in reply to: DarrenP
Where what what?! You alluded to there being a fix for the Revit LT 2013 ribbon... where is it on Autodesk.com? There is one for Revit 2013, not Revit LT 2013.
Active Contributor
bcarriere
Message 9 of 10 (551 Views)
06-05-2013 05:37 PM in reply to: eddierocketship
For some reason Revit users think Revit service packs and hot fixes apply to Revit LT and they do not!
alisder.brown
Message 10 of 10 (448 Views)
07-12-2013 06:50 AM in reply to: p.day
Installing the 2013 service packs 1 & 2 fixed the issue for me in both LT and full Revit.
Update 1: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20121970&linkID=9273944
Update 2: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20679231&linkID=9273944
Have a read of this Link:
 http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Revit-2014-Corrupts-Revit-2012-and-2013-Ri...
 fixed the issue on all the workstations in my office running 2013 when 2014 was installed.
Regards
Alisder Brown
BIM consultant & application specialist
Autodesk Trainer
