Ribbon bar
3 REPLIES 3
sescadd
523 Views, 3 Replies
Ribbon bar
The ribbon bar is greyed out.  I am onlyu able to use a few options a couple of the bars.
Any Ideas?
3 REPLIES 3
rosskirby
in reply to: sescadd
Are you in a 3D view (perspective)?  Do you have any of the sketch edit commands active (i.e. are there a big green checkmark and big red X near the right end of the ribbon)?
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
David_W_Koch
To add to Ross' list of items to check:  Are you in a drafting view, with a Ribbon tab that has predominantly model commands?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
LisaDrago
Can you post some images of the issue?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
