Revolving Doors
1 REPLY 1
jasonkent91
1233 Views, 1 Reply
Revolving Doors
I've been having a hard time to figure this out, and i have found nothing on the topic i have....
Whenever i try to make a mass of a revolving door, i want to try to make it setup as part of the door family... i do not want to read about curtain system, i just want a revolving door to be available as a regular door component.
so my point is: how do i make a revolving door, and how do i setup this "mass" as part of the door family?
again, WITHOUT USING CURTAIN SYSTEMS.
Bonus: how do i make a proper design of the revolving door when i make it a conceptual mass outside the project. the image attatched is what i have made as a mass and any idea on how to make certain features (like using Mullions for the edges of the window area). this is just so i could make realistic mass' of such things as that to make my projects more beautiful.
1 REPLY 1
maciejwypych
in reply to: jasonkent91
Unfortunately you can't copy a mass from a mass family into a door family, or change a mass family category to door.
You'll need to open a door family template, and model the same "mass" in there. Adjust the wall opening size to suit your revolving door, or apply parameters to the door model that you are creating so it will become parametric.
After you finish, load the family into your project, and it will act as a door.
Maciej
