RevitAPILink.dll not found
1 REPLY 1
sweeks
151 Views, 1 Reply
I'm sure I'm doing something dumb, but whenever I try to run the RevitAPI C# sample program, or a simple class I wrote, I always get the message "RevitAPILink.dll not found" when I start revit.
I've edited revit.ini as instructed and copied the RevitAPI.dll and RevitAPILink.dll in the directory with the sample dll.
Any suggestions?
Thanks.
1 REPLY 1
brettsr
in reply to: sweeks
Hello
I had the same problem, but I solved it.
Be sure, you have installed NET Framework version 1.1 !!!
