How does it benefit the Structural Model to use the Structural check box for Revit Walls created in the Architectural Model ?
Solved by Alaaeldin_Alsahli. Go to Solution.
There are two reasons
Reason1
Selecting structure option in walls will enable the analytical model just in case you need to use it for load calculation or send it for any other structural software to calculate.
For more detailed information about analytical model here is a link
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-DB1B675D-23D7-48D2-B1CC-2930519A50F6
Reason2 for discipline purpose, if the structural option is enabled then you will be able to show only structural walls in a structural specific view
https://screencast.autodesk.com/main/details/08c6d76d-3a1a-49bf-98e3-42a942498155
Did this answered your question?
