Revit view range - linked view
5 REPLIES 5
johanssonjan
1941 Views, 5 Replies
I have a project file that I´m using Revit Links displayed by linked view. I have a issue with a stair that is using a different cut plane even though I´m using displayed by linked view setting. Any solution?
5 REPLIES 5
Lance.Coffey
in reply to: johanssonjan
If you create a new project, and link the original file, do you see the same behavior? (If not, the article Tools for Troubleshooting Unexpected Behavior in Revit has information that could help look for differences.)
Lance Coffey
Technical Support Specialist
johanssonjan
in reply to: Lance.Coffey
Same behavior with a new project file. Tried to remove all linked files and relink original file with the same problem.
For now the problem is resolved with detail lines...
Lance.Coffey
If you could create a sample file (with everything but the stair stripped out) and attach to this thread, I would like to take a look at it to see if we can find what is causing this behavior.
Lance Coffey
Check in VG, linked model, Basics and linked view. Maybe the associated view in the linked model has another level and your view range doesn't works.
cbcarch
Can you use a Plan Region to get the cut plane to the proper depth?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
