Is ther any possibilities to change the Revit View & Sheet Name and Number (multiple) without doing manually each of the sheet? We have created the sheet as per below mentioned naming:
Existing Sheet Name:
Arch-Cover Sheet
Arch-Floor Plan
Arch-Elevation
Arch-Section
Arch-Schedule etc.
Proposed Rename Sheet Name:
A-Cover Sheet
A-Floor Plan
A-Elevation
A-Section
A-Schedule etc.
Thanks in advance!
Solved by constantin.stroescu. Go to Solution.
In such a case I'm using schedule:
Constantin Stroescu
