I have used Revit before, but I just downloaded it again (academic version) to try out a project with it. Unfortunately, it is completely unusable due to the whole interface "jumping" down about an inch when I click in the main model space.
This is due to the toolbars changing when I click, and adding another row or two, which makes the main model area shift down. This is a huge problem because Revit thinks I am dragging the cursor up an inch, when in actuality, the window is just jumping downwards.
If I could force Revit to make those toolbars all show up on the same horizontal space, instead of each one using its own space, it would work as it shoud I think. But I cannot move those "modal" toolbars that appear when I click.
Please help me if you can, because I would really like to get some work done.
I am on a Macbook Pro and Windows XP (not Parallels), if it matters.
