export out from Revit 8.0 from a 3D view, File>Export>DWG. You can change
the options in the export dialog box to export 3D faces or 3D solids.
Import the resulting 3D DWG into Max.
wrote in message news:4846101@discussion.autodesk.com...
i would like to save some revit files and later import them into 3d max for
rendering. the computer i would use for the max rendering would not have
revit installed so what would be the best format to save it in .
that is, can i open 3dmax and use import to bring in the revit file?
