Revit Title Block Families - Revision Schedule
3 REPLIES 3
1208 Views, 3 Replies
Hi all - I am sorry if this is old-hat for everyone, but I am new to Revit (been using ACA for years).
Anyway, I am creating my title block family from scratch and have all the labels and line weights all figured out.  The only thing I am missing is the revision schedule.  I have searched through other threads and videos but cannot locate anywhere how and where to create this schedule table.
I see that in the out of the box template, the schedule is there - but I do not know how to create it in my family.
I appreciate any help (and patience from all you seasoned Revit users) with all due respect and gratitude.
-Dave
3 REPLIES 3
Jason_S
The revision schedule gets created when the titleblock is being created.
If you open the titleblock family and go to the View Tab there should be a Revision Schedule command shown.  When you select that command it will open a Revision Properties menu.  Select the fields needed or wanted and then place that on the titleblock in the desired location.
Hope this helps you out.
Jason_S
in reply to: Jason_S
Forgot to mention you have to drag the schedule from the titleblock project browser location onto the titleblock to place it.
Thanks - that second step wa what I was missing...
