I have modeled a family beam as seen in the photo attached. The top starts flat, then slopes up, down, and goes flat again along the length of the beam. I cannot get other standard beams to find attachments points to the beam. The modeled beam is an extrusion in the family. I've also looked into a sweep-blend with similar failure. What am I missing?!
Thanks!
Maybe you should post this question in the Revit Structure forum?
http://forums.autodesk.com/t5/Autodesk-Revit-Structure/bd-p/153
