Revit Structural Concrete Column
1 REPLY 1
Ark.E.H
385 Views, 1 Reply
I am working on a project that include reinforced concrete column. I'm using concrete column in a architectural project and I have to change the material of the column to some thing suitable for the case. Is this posible? And if it is, i will appreciate if some body can help me with this.
1 REPLY 1
in reply to: Ark.E.H
with the column selected, under the type properties, there should be a material category, click on the three dots and it will bring up the material editor, select the material you want and hit okay.
Autodesk Customer Advisory Groups
