Revit sheet / material
6 REPLIES 6
kitty-toft
410 Views, 6 Replies
I  have made ​​a house, but the walls in the bathroom has different inner wall.
Outside they should be the same.
They have the same material, but looks different.
The house should have the same color
anyone know why it is different?
6 REPLIES 6
L.Maas
in reply to: kitty-toft
Difficult to judge from the screenshot.
Maybe you can put (only) the two different walls in a project, check that they have different color and upload the project to the forum.
Louis
Please mention Revit version, especially when uploading Revit files.
rosskirby
Could the walls be flipped inside-out?  In plan, click on the double-arrow to flip the walls and make sure the inside is on the inside and the outside is on the outside.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
kitty-toft
here is the file, the walls is the right way. 🙂
rosskirby
It appears that you have your Wall Panels Inside and Wall Panels Outside materials labeled incorrectlyor all of your other walls are flipped inside out.  The easiest thing to do would be to edit the bathroom wall type so that the material used is Wall Panels Inside (instead of Wall Panels Outside).  Then go into the material editor and rename the materials correctly.  The other option would be to go in and flip all the non-restroom walls.
Hope that helps.
Ross Kirby
Principal
Dynamik Design
kitty-toft
in reply to: rosskirby
I've seen a long time, but could not see it. thank you very much for your help 🙂
Now it looks good 🙂 I just changed the name on the walls, solved everything in under 1 minute.
L.Maas
Yeah, what Ross was saying
You can see what is happening when in layout view you switch to detail level fine.
Louis
Rail Community
