Revit Server
3 REPLIES 3
emaenda
478 Views, 3 Replies
Revit Server
Hey All.
Just wanted to ask whether there I can be provided with documentation on setting up Revit Server 2013.
My client has several licenses of Autodesk Building Design Suite Premium 2013 and hence wants to set up Revit Server within the LAN. for collaboration.
I am aware of how collaboration works but I want to set this up.. I need expert documentation.
Please assist.
Emmanuel Maenda
Local Autodesk Build Technical Representative, Nairobi, Kenya
3 REPLIES 3
Ricardo-Maturana
in reply to: emaenda
Within a LAN it is easy to set up. If you go on YouTube there are a couple of videos showing how. Also check the Revit wiki page Ricardo A. Maturana 1.416.910.1431 Twitter: @rmaturana
DarrenP
in reply to: Ricardo-Maturana
you can start here: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00005-More_Inf0/0000_Revit_Server
DarrenP
ccollins
Using Revit Server in a LAN does not offer much advantage (if any?)
Revit Server is intended for use with multiple offices over a WAN.
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Rail Community
