Revit Architecture
Distinguished Mentor
41 Kudos
Post 1 of 4
Revit Server question?
411 Views, 3 Replies
10-11-2011 11:55 AM
When sending consultants models we typically sent the file located right on our server.  With  Revit Server users can't get to the Revit Server as a drive letter map (that I am aware of).  How would we continue to send Central models to our consultants?
Thanks for the help.
85 Kudos
Post 2 of 4
Re: Revit Server question?
10-11-2011 01:42 PM in reply to: Caddman13
You need to Save -as and Detach from Central, and rmove any Linked files.
Then post the Revit model(s) to the FTP site. ( and have the engineers do the same when posting. )
cheers
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
Active Member
0 Kudos
Post 3 of 4
11-14-2011 12:21 PM in reply to: ccollins
We've been successfully using the Revit Server Command-Line Utility to cut a local file, and use that to send. This way, if you have multiple models, it can run unattended. It still takes time to convert the server-based worksharing files to a single RVT, but is mush less stressful.
Active Member
0 Kudos
Post 4 of 4
11-14-2011 12:22 PM in reply to: sburke
