Ok I am having so much trouble with this server setup. first of all we are using Revit 2015 and the server is using Windows Sever 2012. here is the setup
Office A is the manager running through a Asus router with port forwarding on say the IP is 200.200.200.1
Office B (other side of the world) has the manager and accelorator on it same set up as here only the ip is 200.200.200.2
office A has a RSN.ini saying 200.200.200.1
office B has a RSN.ini with both ip addresses in it
both offices can see the manager internally to there own ip but the two servers do not see each other. how do you make the two server (central and accelerator) see each other?
p.s. when i run the revit server administrator on Office B it gives me an x through 200.200.200.1 but finds 200.200.200.2
Thanks in advance
yes
200.200.200.1
200.200.200.2
What is the DOS variable RSrole2015 for each server? If your configuration is correct, you should verify the firewall for port 808 and 80 between servers.
